Hi. greetings to the community.
I have a problem, I try this in online mode in fision 360 without results. It never gets connected.
My internet connection is fast, I do not understand why this problem happens. stays in, going online
Thanks in advance.
Solved by krishh0007. Go to Solution.
Welcome to the Fusion 360 Community!
I am sorry to hear you are experiencing this issue! Just to check - is this your first time installing Fusion 360? To diagnose this further, I'm going to have to take a peek at your Application Log file and your Installation Log File. You can find both of those on your computer by following the steps in this guide here. For the Application Log file, I will just need the most recent one (as there will probably be multiple in your folder).
Thanks!
Method 1
Make sure that internet ports 80 and 443 are open and that Fusion 360 domains are whitelisted in your proxy and/or firewall: Ports and Domains required by Fusion 360
Method 2
GET https://a360-statusdashboard.s3.amazonaws.com/autodesk_maintenance.json?AWSAccessKeyId=AKIAI3QZAKZMAFW7REIA&Expires=1739314215&Signature=8gvCKDc6XsblmZxbvZ%2FudKRlfyc%3D 52 Empty reply from server
E Process QueryMaintenanceInfoComplete failed to get responce data Function: static void Ns::ServicesMonitor::QueryMaintenanceInfoComplete(const Ns::HTTPResponse &), Line: 251
I 1466428444983 1466428464983 GET https://ui-dls360.autodesk.com/fusion/version.txt 28 Operation timed out after 20000 milliseconds with 0 out of 0 bytes received
I login start
I login end 0
E login failed 20.5219
E MessageBox Error: Unable to connect to Internet
Please check your network connection and sign into your Autodesk Account to start Fusion 360 and try again later.
Method 3
Method 4
Method 5
Thank you very much krishh0007 .. change the windows proxy setting to Not proxy .. and solve everything. thanks for your support.
You are always welcome,Bernardo Rodriguez
