Hello I use autodesk fusion 360 on an educational license and after I joined a new team, I cannot access my old projects from my original team. They don't appear anymore and there's no option for me to switch back onto my original team and even links I have sent to other people of my past work won't open anymore. Is there I way I can get my old projects back?
Thank you.
Solved by HughesTooling. Go to Solution.
Have you selected your old team in the data panel?
Mark Hughes
Owner, Hughes Tooling
Can you sign into your old hub in a browser? You might need to sign out of the hub you are in at the moment then sign back in using your old email or username.
Mark Hughes
If you go to this link it'll open your default hub, then sign out and then sign back in using your old details.
Mark Hughes
