Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
FUSION 360 CRASHING
15 REPLIES 15
Message 1 of 16
coryharris323
590 Views, 15 Replies
FUSION 360 CRASHING
since the last update fusion360  is crashing every time i do a pattern function can anyone help with this
cheers
 cory
15 REPLIES 15
Message 2 of 16
What type of pattern, sketch, body or component?  You could also post your log files.  Also are your submitting your Fusion 360 Crash Reports?
John Hackney, Retired
Message 3 of 16
it has not been sending reports i will try and attach the diagnostic log files i have issues with fusion 360 every noe and again after and update. The pattern is a pattern along a path it is an extrusion of words
Message 4 of 16
Is this the type of pattern you are having issues with?
Message 5 of 16
yes that's very similar but mine is on a straight path and is multiple words 10 stacked in a vertical line
Message 6 of 16
we need the design you are working with.  The log files can help with some areas, but for this kind of issue, we need the model itself, and some information about what you are patterning (faces, bodies, features), and what path you are using.
Jeff Strater
Engineering Director
Message 7 of 16
i will post model as soon as i can get fusion to open it again currently it crashes when opening this file i just updated the graphics driver hopefully this will help
Message 8 of 16
here are the files
cheers
cory
Message 9 of 16
here are the files
cheers
cory
Message 10 of 16
First of all, your second sketch is a mess! (see screen capture) You had projected geometry which was missing it's reference, that is the sketch background color of the timeline icon was yellow.  I got rid of that error but the rest of the sketch is unconstrained and a total mess.  I left it for you to straighten out.  I do not know the text font you used, I must not have it since when I try and edit the text, it changes to Arial on my system.  Anyway with any editing, the font switches to my default Arial.  The model opens quickly, at least my version, your font may be the issue I do not know.  There was a mesh object in the timeline I could not figure out what it was so I deleted it.  Patterning a pattern is not a very efficient way to do your pattern.  Notice in my model I used a one rectangular pattern to accomplish the same thing.  My model is attached with a different name.
By the way, I never had a crash on yours or my model.
Message 11 of 16
that is basically what I am trying to achieve but i would like to fill the board with it i was having issues trying to get it to do 3 but even now my fusion crashes when i try and change yours to say 10 instead of 3. that sketch was just to allow me to shape the board i still may change that. that is probably why it was all over the show. thanks for the help rectangle pattern is really what i was after hopefully i can sort why  fusion is playing up and fix this design.
Message 12 of 16
it looks like this design has a successful Pattern on Path in it.  But, this is a LOT of geometry to try to pattern.  Does Fusion actually crash (i.e. you get a crash dialog), or is it just slow?  How long did you let it run?  Did you Force Quit Fusion?
It will take a LONG time to try to pattern this kind of geometry.  One thing I noticed is that you have the pattern type set to "Adjust".  This is by far the slowest type of feature pattern - it can take up to 10x longer to pattern using this type over the "Optimized" feature pattern:
I switched the type to Optimized, and changed the count to 5.  Then, I let it run, and eventually it produced this:
Jeff Strater
Message 13 of 16
I believe it crashes as it goes non responsive then force closes and now is sending microsoft a report i just tried to reopen fusion and it wouldn't open at all. i will try to do what you have done and change it from adjust when i can get it to run again.
cheers
cory
Message 14 of 16
here is the version with a 5 count
Jeff Strater
Message 15 of 16
jeff_strater
in reply to: jeff_strater
and, here is the 10 instance version, including the first extrude, so that the pattern is complete:
It is very important that everyone understands the difference between a crash (in which Fusion stops running entirely, and you get a crash dialog), and an operation which takes a long time.  In this case, the resulting file is 60MB in size, has 76,000 faces, 225,000 edges, and 150,000 vertices.  You are asking Fusion to compute a LOT of geometry here, and it is going to take some time.  I think it takes around 20 minutes to compute this pattern on my 2018 MacBook Pro.  Something that is this complex is going to be slow, and you should expect that.  That is not a crash.
I've been trying to think of an appropriate analogy, and have not yet settled on a good one.  But one that comes close is the difference between building a doghouse, a single-family house, and a 20-story office building.  You can build a doghouse in an afternoon, you can build a single-family house in a few months, and the office building will likely take 2-3 years.  No one expects to build an office building in an afternoon.  You would not say that the building process has failed because that building is not done in a day.
Jeff Strater
Message 16 of 16
That makes sense so I am probably overloading the cpu would that be more of the problem. I havent been able to open this in fusion but I will leave it  for an hour or so I'm running a 2018 hp work book with 16gb ram and i5 processor is it more likely that that is holding this back. I have had is send error reports to Microsoft
Cheers
Cory
