Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Fusion 360 crahses when opening from my computer
2 REPLIES 2
333 Views, 2 Replies
Hello team, desperately want a fix here:
I have uninstalled and reinstalled fusion 360 and the same issue persists:
https://www.loom.com/share/5cba6fbc27b7459cbd32cb143a7fc9dd
I cannot even open and view my computer to open or save local files, instantly freezes and crashes without a report.
Any and all help would be appreciated.
AH
Labels (1)
2 REPLIES 2
lance.carocci
@Anonymous, if you have Chitubox installed, please uninstall all versions before confirming that Fusion 360 works again. Then, reinstall the latest Chitubox and see if the issue returns. Alternately, you might try their 32-bit version, if available.
This is just a workaround for now - Chitubox's Explorer extension that generates STL thumbnail previews seems to be causing issues when accessed through Fusion, and we hope to address this in a future fix.
Lance Carocci
Fusion QA for UI Framework/Cloud Workflows, and fervent cat enthusiast
in reply to: lance.carocci
Thanks Lance, worked like a charm!
