Hi @Anonymous,
Thanks for asking this in the Forum.
Your post got somehow into the German Forum.
Here is the link to the english one.
http://forums.autodesk.com/t5/fusion-360/ct-p/1234
You just log into Fusion 360 with your Autodesk credentials.
To check your subscription status, you can just click on "Help" and "About"
Here you can see your entitlement.
I hope this helps.
Hi @visserCGWTG,
Thanks for sharing this.
Could you may share a screenshot and your email address that I can check your subscription status?
Thank you,
People should not be sharing email address in a world wide user forum. They should be private message you that info... Anyhow my 2 cents..
Mark Lancaster
& Autodesk Services MarketPlace Provider
@Anonymous @visserCGWTG,
Yes, Mark is right, I have forgotten to mention to use private message in case you would like to share your email address.
Hello @Anonymous,
Welcome back to the forum. To try and resolve this issue in the meantime try following some of these steps:
Resetting and Changing Your Autodesk Account Password & Try to sign-in again
How to do an automatic clean uninstall for Autodesk Fusion 360
Using Adlogin.exe and Microsoft Network Monitor to troubleshoot Fusion 360 Sign-in issues
I will also move this over to the Fusion 360 forum for you to receive more feedback.
Thank you for posting.
Please "Accept As Solution" if a reply has helped resolved the issue or answered your question, to help others in the community.
Natasha
Community Product Support Specialist
Helpful Links:
AutoCAD Videos | AutoCAD Crashes or Freezes | AutoCAD Customer Council | AutoCAD System Requirements | Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
Thank for your reply,
It turned out that because someone else purchased the subscription Autodesk created a new account and assigned it to that one. The reseller reassigned moderatorship to my Autodeskaccount. I just found out I actively had to unassign Fusion 360 from the other account and assign it to mine. That explained why the "term expired" kept popping up.
I think I got it all covered now.
Hi @visserCGWTG,
Thank you for the update.
I´m glad that you have access to Fusion 360 now.
Please, keep us updated in case you have more questions.
Thank you,
