Fusion 360 Activation
This widget could not be displayed.
I have a Free Trial of Fusion 360 that has expired. I have purchased a subscription and have the Product ID & Serial Number. When I open Fusion there is no pop up screen showing me where I can register the software. How do I go about getting this registered and activated?
Replies (8)
Mike.Grau
Hi @Anonymous,
Thanks for asking this in the Forum.
Your post got somehow into the German Forum.
Here is the link to the english one.
http://forums.autodesk.com/t5/fusion-360/ct-p/1234
You just log into Fusion 360 with your Autodesk credentials.
To check your subscription status, you can just click on "Help" and "About"
Here you can see your entitlement.
I hope this helps.
visserCGWTG
That's not waht it says in the screen when I follow those steps.
Mike.Grau
Hi @visserCGWTG,
Thanks for sharing this.
Could you may share a screenshot and your email address that I can check your subscription status?
Thank you,
Mark.Lancaster
@Mike.Grau
People should not be sharing email address in a world wide user forum.  They should be private message you that info...  Smiley Wink   Anyhow my 2 cents..
Mark Lancaster
Mike.Grau
Hi @Mark.Lancaster
@Anonymous @visserCGWTG,
Yes, Mark is right, I have forgotten to mention to use private message in case you would like to share your email address.
natasha.l
Hello @Anonymous,
Welcome back to the forum. To try and resolve this issue in the meantime try following some of these steps:
Resetting and Changing Your Autodesk Account Password & Try to sign-in again
How to do an automatic clean uninstall for Autodesk Fusion 360
Using Adlogin.exe and Microsoft Network Monitor to troubleshoot Fusion 360 Sign-in issues
I will also move this over to the Fusion 360 forum for you to receive more feedback.
Thank you for posting. Smiley Happy
Please "Accept As Solution" if a reply has helped resolved the issue or answered your question, to help others in the community.
visserCGWTG
Thank for your reply,
It turned out that because someone else purchased the subscription Autodesk created a new account and assigned it to that one. The reseller reassigned moderatorship to my Autodeskaccount. I just found out I actively had to unassign Fusion 360 from the other account and assign it to mine. That explained why the "term expired" kept popping up.
I think I got it all covered now.
Mike.Grau
Hi @visserCGWTG,
Thank you for the update.
I´m glad that you have access to Fusion 360 now.
Please, keep us updated in case you have more questions.
Thank you,
