Form Editing issue in Sculpt after being in Model/Patch..?
I've had this issue before and was helped by someone on this forum the last time; however, the previous fix doesn't seem to be working this time around. I am currently just learning this software and trying to gain experience with little projects so I am rather unfamiliar. I apologize in advance if this seems like a simple mistake that could be solved by properly learning the software. I'm just doing this for fun in my free time to test the waters. Anyway, it seems that every time I enter into patch/model or rendering mode and then return to sculpt my design is transparent and I am unable to select bodies/segments/vertices etc to edit. I am unable to select different purple icons from my timeline as well. Am I misunderstanding how one is to access/use the timeline function? This seems to happen every time I reach this stage in a design and I'm kind of just stuck unable to modify or create further. Hopefully someone can clear this up for me. Thanks in advance!
Also, I'll include my project to better explain my "issue"
TrippyLighting
You have two purple T-Spline icons in the timeline.
The first one contains the geometry for the car, the second none, however, is empty and can be deleted.
If you want to edit the remaining T-Spline you can double-click on the icon in the timeline or right-click on the icon and select "edit feature".
A little tip on your T-Spline. It contains too many edges/geometry which will make it difficult to control/edit. Also, as a beginner stick to quad geometry, meaning use only polygons with 4 edges and vertices.
As a general rule of thumb use the least amount of polygons necessary and only when you are happy with the overall proportions should you add smaller details. If you find that you need to stretch polygons to high aspect ratios to achieve a shape, then add edge loops.
Also, model mostly in box view mode and check the shape in smooth view mode. Not the other way around!
Also, avoid the subdivide/precise function.
Thank you for the response! The issue I'm currently having is that when I attempt to double click or right click on the Timeline icons, nothing happens. That fixed my problem immediately the last time but for some reason I get no feedback from interacting with the Timeline at the bottom of the screen now.
And just to clarify. Box mode view is working in Sculpt whereas smooth view is when in "Finish Form"?
Also, anyway to fix the damage that occurred using subdivide? Is it as simple as deleting the unwanted segments/vertices?
TrippyLighting
I cannot really help with that other than suggesting the usual in that order:
1. Close and restart Fusion. If that does not work
2. Close Fusion and root the computer. If that does not work.
3. Uninstall Fusion and re-install it.
No. These three view modes are available when editing a T-Spine only. They can be accessed from the menu:
Or when editing the T-Spline they are also accessible form the edit form menu panel:
They also have keyboard shortcuts:
When you click "Finish form",  if the T-Spline does not enclose a volume watertight, then it will convert into a NURBS surface, otherwise it'll convert into BRep (solid body) containing NURBS surfaces.
Yep. Just select an edge, or double click on an edge select a whole edge loop and hit the delete key.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
