Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
FORCED INTO TRIAL AND TEAM ACCOUNT, NOW MISSING OLD PERSONAL PROJECTS
19 REPLIES 19
Message 1 of 20
keeper1
586 Views, 19 Replies
I just reopened fusion to work on a project and was forceable signed out for no reason and when I signed back in it required me to make a team. After doing so I can only see the empty default and admin projects for the team with my old personal projects completely missing. There is no support available because I do not have the ability to pay nearly $1k a year for software I use maybe twice a year and Autodesk doesn't offer any type of support even when it is their actions that break years of work.
19 REPLIES 19
Message 2 of 20
@keeper1 @Can you please direct message me your email ID that you used to register for Fusion? I can ask our teams to look at what is happening
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 3 of 20
@keeper1 Thank you for sending in the email ID. I am having our engineering team verify in the back end.
Autodesk Fusion
Join Fusion Insider
Message 4 of 20
@keeper1 When you login to Fusion and go to the data panel, can you please go to the hub switcher dropdown and send us an image of all the hubs you have there? Do you see a "Single storage hub" in there?
Autodesk Fusion
Join Fusion Insider
Message 5 of 20
I have no options other than the team I was forced to create.
Message 6 of 20
@keeper1 When you had the email ID change, did you create a new account or asked for the old account to have the new email ID? Any change you can log in using the older email ID and see what happens?
In the backend we are not seeing any evidence that the new team was created from an "older" single user hub.
Autodesk Fusion
Join Fusion Insider
Message 7 of 20
The old account email does not exist in the system when I attempt to login, only the new one. It should have been a change of email and not making a new account as that is the steps I went through todo so.
This is the message I get when trying to use my previous email instead of my current one.
Message 8 of 20
@keeper1 Can you please let me know when you made the change of email address and when it was approved? Having this information will help to go back to the engineering team to investigate.
Autodesk Fusion
Join Fusion Insider
Message 9 of 20
June 5th of this year
Message 10 of 20
@keeper1 Thank you. I am taking all this information back to engineering. Will keep you posted.
Autodesk Fusion
Join Fusion Insider
Message 11 of 20
@keeper1 Another quick question, did you reach out online or with the customer support for the email change?
Autodesk Fusion
Join Fusion Insider
Message 12 of 20
It was 2 months ago, I don't remember at this point.
Message 13 of 20
karina.harper
in reply to: keeper1
@keeper1
Are you using Fusion on the same computer as before? If so, can you navigate to your local cache and take a screenshot of the complete contents of this folder:
Windows: %localappdata%\Autodesk\Autodesk Fusion 360
Mac: Library > Application Support > Autodesk > Autodesk Fusion 360
Cheers,
Karina
Karina Harper
Software QA Engineer, Fusion 360
Fusion 360 Webinars | Contact Support | EDU Support | Support Board Best Practices
Message 14 of 20
keeper1
in reply to: karina.harper
I have reinstalled windows since changing my email so it might as well be a different PC
Message 15 of 20
@keeper1 We are not able to find any records for the email ID change nor the single user hub to team user hub change.
1. If you go into https://login.autodesk360.com/login
2. Go into "Archived " - Do you see your project in there?
Autodesk Fusion
Join Fusion Insider
Message 16 of 20
I do not see an archive option unless I am looking in the wrong place
Message 17 of 20
I have no archived projects, I cannot login to my previous email as it states it is not an account. The only thing I have now is my current account which forced me into the stupid team account and removed all my previous projects
Message 18 of 20
@Andy.Spivey and @porkodi_autodesk We have @keeper1 that went through  a single hub transfer into team hub and now cannot find any of their files. Checking in support does not give any details in their team hub. What are our other opportunities to see I the project transfer happened successfully or not?
Autodesk Fusion
Join Fusion Insider
Message 19 of 20
//edit for grammer
Thank you for the tag Raj.
@keeper1 - I just sent you a DM with some information.
We checked the account information provided and sent you some information on the original account where your data is located and when the original account email was changed.
The account that you had subsequently logged in as was a new account/email to the system, so a new hub was provisioned.
Please let me know if there are any questions regarding!
-Andy
Andy Spivey
SQA Engineer
Message 20 of 20
@keeper1 To close out this thread, Andy has discovered that you were logging into the wrong email and logging back into the correct email had all of your projects. Hope this has resolved all your concerns.
Autodesk Fusion
Join Fusion Insider
