Hi there,
So after a day on this i am asking for help.
I have a model of a GPS unit which has some slightly unusual geometry.
What I WANT to do is make a negative of the shape (mold) in two halves, the ultimate goal is to make a new case for it which it will then fit into snugly and two halves will bolt together
The problem I have is that the unit is an assembly of shelled parts (hollow on the inside) so if I combine/cut the model from a block then i get the complicated internal structure rather than the general outer shape.
Boundary fill doesn't seem to fill the way i thought it would (so it doesn't help)
I tried making a forming tool and that failed to work for me, though I admit i am not to great with how to use it..
At the end of the day I can work around this... but i don't want to!
Can anyone give me some advice on how to do it properly, i am going nuts!!!
the original file is here - note i do not want the stand (ref pictures)
https://docs.cubepilot.org/user-guides/3d-printing/here-3-stand
(sorry I tried to upload the isolated model but auotdesk said no)
Thank you in advance
