Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Filling a complicated model?
5 REPLIES 5
209 Views, 5 Replies
Hi there,
So after a day on this i am asking for help.
I have a model of a GPS unit which has some slightly unusual geometry.
What I WANT to do is make a negative of the shape (mold) in two halves, the ultimate goal is to make a new case for it which it will then fit into snugly and two halves will bolt together
The problem I have is that the unit is an assembly of shelled parts (hollow on the inside) so if I combine/cut the model from a block then i get the complicated internal structure rather than the general outer shape.
Boundary fill doesn't seem to fill the way i thought it would (so it doesn't help)
I tried making a forming tool and that failed to work for me, though I admit i am not to great with how to use it..
At the end of the day I can work around this... but i don't want to!
Can anyone give me some advice on how to do it properly, i am going nuts!!!
the original file is here - note i do not want the stand (ref pictures)
https://docs.cubepilot.org/user-guides/3d-printing/here-3-stand
(sorry I tried to upload the isolated model but auotdesk  said no)
Thank you in advance
5 REPLIES 5
g-andresen
I do not want to access unknown sources.
Therefore:
Open the file in Fusion and save it.
Then:
File > Save export as f3d locally > Attach to the next post.
günther
in reply to: g-andresen
Bam.
Thanks for the help
TheCADWhisperer
First thing I would do is turn on Capture Design History.
Next thing I would do is create some Patches to close the openings so that  you have a "watertight" envelope.
In the process of doing these two steps - I noticed that you are missing a fillet?
After taking another look at this - I think I would do a simple Revolve, Extrude and Split.
in reply to: TheCADWhisperer
First of all you are amazing
Second of all, I am definitely subscribing to your channel.
I was trying to "patch" and i tried a multitude of ways to no avail! this is exactly what i wanted to do.
Thank you so much
TheCADWhisperer
Be sure to go back and take another look for symmetry (sometimes it helps to have someone else look).
Technology Administrators
