Fusion Support
Fillet part of an edge
5 REPLIES 5
jani.bolka123
2652 Views, 5 Replies
Hi!
How do i select only part of an edge for fillet shown here:
part of an edgepart of an edge
I seem to only be able to grasp entire circle instead of just part of it
Labels (1)
5 REPLIES 5
Please attach the f3d file here.
File> Export> f3d
Moshiur Rashid
Autodesk Certified Instructor
ACP | CSWE
https://www.autodesk.com/expert-elite/overview
LINKEDIN | FACEBOOK
Here is the file
@jani.bolka123 wrote:
Here is the file
No file is Attached.
You must Attach via web forum, not by email.
When you'll be posting next time, scroll down and you will see the attachment section.
Moshiur Rashid
ACP | CSWE
LINKEDIN | FACEBOOK
sythxx
in reply to: jani.bolka123
Split the body by sketching on the top of the circular disc and use command split body. After splitting the circular disc into equal sectors you can fillet each desired curve
