Hi!
How do i select only part of an edge for fillet shown here:
I seem to only be able to grasp entire circle instead of just part of it
Solved by sythxx. Go to Solution.
@jani.bolka123 wrote:Here is the file
No file is Attached.
You must Attach via web forum, not by email.
Split the body by sketching on the top of the circular disc and use command split body. After splitting the circular disc into equal sectors you can fillet each desired curve
