I've been having trouble uploading files into Fusion 360. Whenever I try and upload a file it is placed in the queue and appears to start to upload, but every file I have tried ends up showing a failed status. Is there something I can do to fix this?
Cheers
Cheers
Solved by rhudaynath. Go to Solution.
Hi @Anonymous ,
Sorry to hear that you are facing a problem in a file upload.
Please share the snapshot of 'failed status', it will help us to understand the situation better.
We also need to check if there is anything pending to upload.
Please share UploadQueuedFileList.xml file with us for checking,
You can find this file at below location,
Mac
Windows
This file has list of the file which are in the process of upload. It might be possible that one of those files got stuck in the upload. In that case, you can refer to below article.
Sharing for reference https://knowledge.autodesk.com/support/fusion-360/learn-explore/caas/sfdcarticles/sfdcarticles/File-stuck-in-upload-queue-in-Fusion-360.html?st=Uploading%20issues
Please help us with the above information, so that we can help you better!
Thank you,
Hi @Anonymous ,
Mac
Windows
Thank you,
I cant find the support folder in the location you described, could that be part of the problem? Would it be worth completely uninstalling and reinstalling fusion?
Cheers,
Cheers,
Hi @Anonymous ,
Thank you for sharing log file, we will look into the reason of file upload failure.
We have logged FUS-65056 to track this internally.
Thank you,
Hi @Anonymous ,
Thank you,
Hi @Anonymous :
As we discussed over email,
File upload was failing as you are using older version of Fusion. After Fusion update, the issue has been resolved.
Please let us know if you see Fusion is not getting auto-updates.
Thank you,
Hi @Anonymous :
Thank you,
