engraving Empty tool path
Hi Team,
I have done a halftone image with the halftone image creator but I have an issue with the sketch. When I want to engrave some parts of the sketch come out on as an empty tool path. I have attache 2 pictures, the first one is the picture with the blue circle and that is the engrave 7 and that comes up with the warning and that is picture number 2. I also attached the fusion file for you to have a look at. The tool path number 6 which is just above comes out okay. Let me know if you need any more information.
  • CAM
g-andresen
Hi Matthias,
use the sketch for the toolpath instead of the model.
Note:
The calculation takes several minutes.
günther
