hi
great idea the fasterner function
love it !
i have two suggestions :
1. please merge the 'hole' function with fasteners - it s a bit useless to create a hole and than add a fasterner - that can be done in one step
2. show a list of 'which' fastener(s) and 'how many of those' you have used in the design - would be a great help to plan purchases
those implementations would really help a lot !
hi
love it !
Solved by Roman_Vesely. Go to Solution.
Hi jvh674QU83,
thank you for your feedback.
WRT 2) show a list of 'which' fastener(s) and 'how many of those' you have used in the design - would be a great help to plan purchases
It's already there .... you have to create Drawing from your design with inserted Fasteners and insert Parts List table where you can see both infomration .... fasteners info (like description) + quantity
Best regards
Roman
Hi jvh674QU83,
Best regards
Roman
tnx for this !
and waw that solution is well hidden 😉
and i m not going through the drawing for production...
why don t you add that in the fasteners list in the browser ?
now you have for every location one complete set of the same fasterner
can you imagine if you use 80 fasteners
would be better to add the name of the fastener (with the number of used behind it)
+ for each fastener used a body
tnx for this !
Hi jvh674QU83,
unfortunately BOM data are available only in Drawing env. in Parts List table for now.
You don't have to create - I mean Save your drawing. You can create Parts List even into the unsaved/untitled document and do Export to CSV file (from the Export menu - last one on the right in Drawing env).
Regards
Roman
Hi jvh674QU83,
Regards
Roman
@Roman_VeselyAre there any plans to improve the BOM workflow for fusion in the future?
Hi jordan783ZS,
BOM management is already implemented as part of the Fusion 360 Manage with Upchain.
Regards
Roman
Hi jordan783ZS,
Regards
Roman
Yes,
yes, it's a separate product working with Fusion.
if you are inresting to know more about new / upcomming Fusion features (or Preview Features), you can Sign In to
Autodesk Feedback Community
Regards
Roman
Yes,
Regards
Roman
