Fusion Support
Failed Update
12 REPLIES 12
Message 1 of 13
981 Views, 12 Replies
Failed Update
Update failed to install. Cleaned Fusion360. Reinstall failed. See attachment.
12 REPLIES 12
Message 2 of 13
julia.paganucci
Hi @Anonymous,
Welcome to the Fusion 360 community!
It looks like you're getting an error that's referenced in this article. Please do the following:
  • Perform a clean uninstall of Fusion 360 using the Fusion Cleanup Tool
  • Make sure you Clear the TEMP folder
    1. Click the Windows Start button.
    2. In the Run box type %TEMP% and press Enter
    3. Highlight and delete all files. Ignore any files in use.
  • Disable User Account Control from Control Panel
    1. Access User Control Panel from Start Menu > Control Panel User Accounts and Family Safety > User Account.
    2. Click on User Account Control settings.
    3. Move the Slider to Never Notify.
    4. Click OK to make the change effective.
    5. Restart your computer.
  • Disable any antivirus
  • Re-download Fusion 360.
  • Run the installer as admin - right-click > Run as administrator
Please accept as solution if my post fully resolves your issue, or reply with additional details if the you are still not able to install Fusion 360.
Thanks!
Julia Paganucci
Technical Support Specialist
| Autodesk Knowledge Network | My Screencasts | Fusion 360 Webinars | Tips and Best Practices
Message 3 of 13
in reply to: julia.paganucci
Now unable to download Fusion360
Message 4 of 13
julia.paganucci
Hi @Anonymous,
Can you please expand on what is happening now? Can you try to re download Fusion from here? Are you receiving any error messages that you can screenshot?
Julia Paganucci
Message 5 of 13
I uninstalled Fusion360 in windows10 then I ran Fusion360 cleaner. Both
completed successfully. Then I downloaded Fusion360 installer from your
email link. Instalization went to 99% then error msg. See attached files.
I have been using Fusion360 successfully on this computer for over a year
until I received the update error message.
Please advise me if you need any other information from me.
Thank you, Ted Miller
Message 6 of 13
julia.paganucci
Hi @Anonymous,
The files must not have attached for some reason!
To find out why you're having installation problems can you please attach your log files. You can follow these directions to locate the installation log files
Julia Paganucci
Message 7 of 13
autodesk.webdeploy.streamer.log
(79K
fusion360.cleaner.log
(1K)
(226K)
(183K)
These files
appeared to attach.
Ted
Message 8 of 13
julia.paganucci
Hi @Anonymous,
There are still no files attached. When you're replying to the post, are you scrolling down (past the screencast insert section) to the attachments? Please make sure that the remove icon is next to your file to conform that it is completely attached to the post.
Julia Paganucci
Message 9 of 13
Another attempt.
Message 10 of 13
julia.paganucci
Hi @Anonymous,
Please try :
  1. Perform a manual clean uninstall instead
  2. Clear the TEMP folder and disable user account control from control panel (steps in my original response)
  3. Re-download fusion 360
  4. Run Fusion as admin (right-click > Run as administrator)
If this doesn't work, please attach a new copy of your log files. Thanks!
Julia Paganucci
Message 11 of 13
Reinstall failed at 99%.
Files attached.
Message 12 of 13
I reset Windows10 then Fusion360 installed and updated.
Thank you for your help.
Message 13 of 13
JBerns
In the event of a failed Fusion 360 Update, should we add to this post or create a new post?
Jerry
CAD Administrator
Using Inventor 2022
Autodesk Certified Instructor
Autodesk Inventor 2020 Certified Professional
Autodesk AutoCAD 2017 Certified Professional
