Hi @Anonymous,
Welcome to the Fusion 360 community!
It looks like you're getting an error that's referenced in this article. Please do the following:
Please accept as solution if my post fully resolves your issue, or reply with additional details if the you are still not able to install Fusion 360.
Thanks!
Hi @Anonymous,
Can you please expand on what is happening now? Can you try to re download Fusion from here? Are you receiving any error messages that you can screenshot?
Hi @Anonymous,
The files must not have attached for some reason!
To find out why you're having installation problems can you please attach your log files. You can follow these directions to locate the installation log files.
Hi @Anonymous,
There are still no files attached. When you're replying to the post, are you scrolling down (past the screencast insert section) to the attachments? Please make sure that the remove icon is next to your file to conform that it is completely attached to the post.
Hi @Anonymous,
Please try :
If this doesn't work, please attach a new copy of your log files. Thanks!
Reinstall failed at 99%.
Files attached.
I reset Windows10 then Fusion360 installed and updated.
Thank you for your help.
In the event of a failed Fusion 360 Update, should we add to this post or create a new post?
Jerry
