Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Failed update attempts.
6 REPLIES 6
kshea9RNL8
611 Views, 6 Replies
Tried numerous times thinking it was the slow internet connection but no completed update, gets to 99% and then eventually fails.
The log report is attached.
Labels (1)
6 REPLIES 6
jhackney1972
in reply to: kshea9RNL8
The log file you said is attached did not make it.  Please attach it again.
John Hackney, Retired
kshea9RNL8
Dang this slow internet connection.....
Tags (1)
jhackney1972
The install application did not have enough permission to remove existing files needed for update installation.  I think you need sign out of your current account and log in using one which has full administrator rights to your system.  Then I would use the Fusion 360 Clean Uninstall tool, then restart again logging back in with a full administrator account.  I would temporarily turn off Windows User Access Control (UAC) for the account and then re-install.
kshea9RNL8
in reply to: jhackney1972
Appreciate the reply and thank you, Fusion 360 works fine with out the update, for the time being at least I'll leave it as is. Takes hours to download then to spend more hours waiting till the Update installs. I've never had a program requiring more re-installs then Fusion 360.
kshea9RNL8
Just checked, I do have administrator rights, I presume it is full, do recall one can have partial administrator rights. No doubt re-install will fix it though.
kshea9RNL8
Never gave the User Account Control  any thought, turned it off and downloaded the update and it did install.
Any one else run into a failed install might give that a try befor a re-install which was my next move.
