Fusion Support
Extrude sketch that changes along path
2 REPLIES 2
JalteJKR
437 Views, 2 Replies
Hi, I've made a sketch on a plane that moves along the path of the curved surface, and on this sketch, I've made an arc whose top part is constrained by the path above the curved surface. The goal is to extrude the arc and have it fade out toward the edge. If I move the plane along the path, the sketch does exactly what I want it to, but I can't find a way to extrude it so that it follows the sketch along the path. Can anyone help?
2 REPLIES 2
g-andresen
in reply to: JalteJKR
surface loft + offset surface + patch +stitch + combine will do it.
günther
JalteJKR
in reply to: g-andresen
Beautiful, thank you
