I am having trouble exporting my files for 3D printing. It worked fine yesterday, but as of this morning after the update, I am consistently getting failed messages on the job status board. Is this related to the new update or am I doing something wrong all of the sudden? Thanks for any help!
Solved by wmhazzard. Go to Solution.
Exporting an STL works for me but I see zero reason to use the export function. Just right click on the body or component and select save as mesh, then save as 3MF (preferred) or STL, it is much faster, has more options and has no problems.
Thank you that worked perfectly. I did not know you could do it that way. I am not sure what a 3mf file is so I just used obj and it worked perfectly. Thank you again for that help.
