Can someone help with the issue I have when exporting a drawing sheet as a dxf file. The drawing contains a flat pattern view with bend notes on the bend lines as shown in the image. I'm using the Export sheet as dxf feature, when importing into other software the bend notes do not show up. Although they do show when I upload the file to Autodesk online viewer. I'm wondering if the problem is due to the AutoCAD version being exported from Fusion. Is it possible to export as an older version than 2013?
Solved by ianjwellings. Go to Solution.
Please ignore this post. The issue was with the CAM software importing the dxf file.
