Export Flat Pattern DXF Bug?
HughesTooling
HughesTooling
There's a request on the ideastation that I think is a bug so thought I'd make a post here to demonstrate.
The problem is if you open a design, activate a flat pattern then export as a DXF the file is flagged as edited and if you have autosave enable you get a new version. This can cause a lot of problems if the design is part of an assembly and\or has a 2d drawing as they will then need updating. The reason I think the is a bug is there's no problem just activating a flat pattern then exiting the flat pattern, it's only if you export the DXF the file shows as edited.
Mark
Mark Hughes
Owner, Hughes Tooling
karina.harper
Autodesk Support
Autodesk Support
Hi @HughesTooling
Thanks for bringing this up. Would you mind sharing the file so we can explore it/attach it to the request?
Karina Harper
Software QA Engineer, Fusion 360
Fusion 360 Webinars | Contact Support | EDU Support | Support Board Best Practices
HughesTooling
Any simple sheet metal part will do, see attached.
Mark
Mark Hughes
karina.harper
Autodesk Support
Autodesk Support
That works. I've logged it with the dev team.
(internal FUS-46899)
Karina Harper
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
