able to export a body as a dxf, iges or step format on a right button Click
I can only guess what you are trying to convey with your forum post. You want to have some right click features added to the right click menu. Well next time, you need to "state" your request a bit more clearly instead of having others guess what you desire. Unless the reader is very familiar with Fusion 360, and knew these right click options did not currently exit, would not understand what your post is about.
I am assuming you know these options are already located under Export but I assume left click there is too much effort.
John Hackney, Retired
This is old, but it still came across my google search. In short, you want components and not bodies. You can right click and export individual Components (as many file types), but not bodies. It seems with bodies a lot of people are saving them as stl's and then converting them, I assume because they don't know Fusion 360 that well; and the way it handles "assemblies" is quite different than other software I've used.
If you use the top menu to export as the other toxic human being commented before me, you'll export every body and component in the project.
So if you want to export individual parts, each part needs to be its own "component" not a separate "body." I still get hung up on this as I only use Fusion 360 once in a while for work, and recently created a project with different bodies instead of components myself.
@Bryan.Hook wrote:This is old....
Did right click Export Component exist back then?
