Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Error shows up every time I launch: 3 x AddIn: Cannot load Dll - Could not load the addin in ...Applications/Simulation/SimPostProcessingUI10.dll AddIn: Cannot load Dll - Could not load the addin in
6 REPLIES 6
OceanHydroAU
418 Views, 6 Replies
AddIn: Cannot load Dll - Could not load the addin in ...Applications/Simulation/Extensions/FEACSObjectsExt/SimFEACSObjectsUI10.dll
AddIn: Cannot load Dll - Could not load the addin in ...Applications/Simulation/Extensions/FluidDynamicsExt/SimFluidDynamicsUI10.dll
AddIn: Cannot load Dll - Could not load the addin in ...Applications/Simulation/Extensions/InjectionMoldingExt/InjectionMoldingUI10.dll
2 x AddIn: Cannot load Dll - Could not load the addin in ...Applications/Simulation/SimPostProcessingUI10.dll
AddIn: Cannot load Dll - Could not load the addin in ...Applications/Simulation/Extensions/LinearStaticStressExt/SimLinearStaticStressUI10.dll
AddIn: Cannot load Dll - Could not load the addin in ...Applications/Simulation/Extensions/TemplateExt/SimTemplateUI10.dll
AddIn: Cannot load Dll - Could not load the addin in ...Applications/Simulation/Extensions/ThermalSteadyExt/SimThermalSteadyUI10.dll
AddIn: Cannot load Dll - Could not load the addin in ...Applications/Simulation/Extensions/ThermalStressExt/SimThermalStressUI10.dll
AddIn: Cannot load Dll - Could not load the addin in ...Applications/Simulation/Extensions/ThermalTransientExt/SimThermalTransientUI10.dll
2 x AddIn: Cannot load Dll - Could not load the addin in ...Applications/Animation/NaAnimation10.dll
AddIn: Cannot load Dll - Could not load the addin in ...Applications/Animation/NaAnimationUI10.dll
AddIn: Cannot load Dll - Could not load the addin in ...Applications/Animation/NaSmartObjectUI10.dll
I had a look to find where these files are:  AppData/Local/Autodesk/webdeploy/production
$ for FN in SimPostProcessingUI10.dll SimFEACSObjectsUI10.dll SimFluidDynamicsUI10.dll InjectionMoldingUI10.dll SimLinearStaticStressUI10.dll SimTemplateUI10.dll SimThermalSteadyUI10.dll SimThermalStressUI10.dll SimThermalTransientUI10.dll NaAnimation10.dll NaAnimationUI10.dll NaSmartObjectUI10.dll;do find | grep $FN;done
./4826aec956713f599d57385857ff62484fd50dd3/Applications/Simulation/SimPostProcessingUI10.dll
./4826aec956713f599d57385857ff62484fd50dd3/Applications/Simulation/Extensions/FEACSObjectsExt/SimFEACSObjectsUI10.dll
./4826aec956713f599d57385857ff62484fd50dd3/Applications/Simulation/Extensions/FluidDynamicsExt/SimFluidDynamicsUI10.dll
./4826aec956713f599d57385857ff62484fd50dd3/Applications/Simulation/Extensions/InjectionMoldingExt/InjectionMoldingUI10.dll
./4826aec956713f599d57385857ff62484fd50dd3/Applications/Simulation/Extensions/LinearStaticStressExt/SimLinearStaticStressUI10.dll
./4826aec956713f599d57385857ff62484fd50dd3/Applications/Simulation/Extensions/TemplateExt/SimTemplateUI10.dll
./4826aec956713f599d57385857ff62484fd50dd3/Applications/Simulation/Extensions/ThermalSteadyExt/SimThermalSteadyUI10.dll
./4826aec956713f599d57385857ff62484fd50dd3/Applications/Simulation/Extensions/ThermalStressExt/SimThermalStressUI10.dll
./4826aec956713f599d57385857ff62484fd50dd3/Applications/Simulation/Extensions/ThermalTransientExt/SimThermalTransientUI10.dll
./4826aec956713f599d57385857ff62484fd50dd3/Applications/Animation/NaAnimation10.dll
./4826aec956713f599d57385857ff62484fd50dd3/Applications/Animation/NaAnimationUI10.dll
./4826aec956713f599d57385857ff62484fd50dd3/Applications/Animation/NaSmartObjectUI10.dll
it looks like leftovers from one of your surprise "free trial" evaluation things that happened (without my consent) when I clicked a wrong item in a menu some moths ago?
Tags (1)
Labels (1)
6 REPLIES 6
k1lb553cs
in reply to: OceanHydroAU
The exact same thing is happening to me. I reinstalled my whole computer and even switched motherboards but it still keeps happening.
@OceanHydroAU @k1lb553cs Apologies for the late reply but if you are still facing this issue please do the following:
  • Close Fusion
  • Go to Media Feature pack for Windows
  • For the Windows version their machine is select the right media pack
  • Install media pack
  • Restart machine (not sure if this is needed but worth recommending)
  • Launch Fusion
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
hi Rajkumar, are jou sure that  Media feature pack for windows has something to do whit this error? have your thy this out by yourself? i have Windows 10 pro N version 22H2 what is not in the list. and this error came with an update from fusion 360 e few months ago.
Who has the same problem?
Thanks in advance
@frans_van_enschot 22H2 is the last two in the list. Are you still having this issue ?
Autodesk Fusion
Join Fusion Insider
HI, Thanks for the solution 😀
I can confirm that I was having the same errors on start up but this has fixed the issue.
Hi Reykumar,
It works.
Thank your very very very much.
Your the master.
Add media feature must don on my system on an other place.
Start->System-> add features
Thanks for your help
