Announcements
Direct mesh edit has gone missing?
kalenPKLZ9
kalenPKLZ9
After importing a scan i went to do a little bit of cleaning up and noticed the button for direct mesh edit has completely gone, is this due to an update or is it a unique issue just for me?
Replies (11)
jeff_strater
It still should be there as far as I know.  Right click on the mesh in the browser, or in the Edit dropdown on the Mesh tab:
Screenshot 2023-01-19 at 3.58.40 PM.pngScreenshot 2023-01-19 at 3.59.00 PM.png
Jeff Strater
Engineering Director
kalenPKLZ9
Mine is simply not there 😕
jeff_strater
I don't think that this is tied to an extension of any kind.
Try resetting your customization (right click in the tool bar, and do both of these):
Jeff Strater
jhackney1972
Also you can see if it is available by typing "S" on the keyboard to bring up the Shortcut Menu and then typing in "Direct Edit" to see if you can find it that way.
John Hackney, Retired
kalenPKLZ9
kalenPKLZ9
still nothing, Very strange
TheCADWhisperer
@kalenPKLZ9
If you start a new blank file - is it there?
Just as a "sanity check" Can you File>Export your *.f3d file that exhibits this behavior to your local drive and then Attach it here to a Reply?
Edit:  Do you have Capture Design History turned on?
jeff_strater
ah, @kalenPKLZ9 , I suspect that @TheCADWhisperer has the answer.  Direct Edit does not make sense in a Direct Modeling design, because all editing is direct.  Direct Edit in a history-based/parametric design effectively allows you to make some Direct Modeling edits to a mesh that are not captured.  But, that is not needed in a Direct Modeling design.
Now I feel bad for not seeing that earlier...
Jeff Strater
tran.t.duc
Observer
Observer
I have the same issue, I can't direct edit (mesh) a filed that was imported. I wonder if that's the issue.
t_boerboom
Community Visitor
Community Visitor
Welll afther reading message 9 I tought i had the awnser. And i did 🙂 The problem is that you do not have Capture design history activated... When you do, direct edit becomes visible 🙂
kiritoluffysao
Community Visitor
Community Visitor
This is the anwser, thank you for that saves me so much headace
