Hi guys, I connected two parts but i found these line. How to erase these lines showing down? please make a video for the solution. I attached a picture and the file.
Solved by memo2022. Go to Solution.
I see reference dimensions.
Not what I instructed.
Attach your file here so that I can see where you went wrong on the instructions.
Wait a minute, did you simply duplicate the dimensions rather than click and drag the existing dimensions to spread them out? Is this the same way you used SolidWorks?
Add a Fillet R2 to the bottom of the smallest hole...
Tip: You might have to hold the Ctrl key in Windows or CMD key on Mac to get multiple edges for the R1.5 Fillets.
Add a Fillet R6.5 to the bottom outside edge of the next hole...
Add a Fillet R1.5 to the top of the hole and to the bottom edges of the o-ring groove.
