Announcements
Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
Fusion Support
edit face command doesn't seem to work correctly
1 REPLY 1
fprico
360 Views, 1 Reply
I am trying to make this tutorial but can not make the shape with the edit face command or tspline first I can't find the way to select edges or all control point from the front and side views. second I can not give a value for the amount of control points.
also when editing the face  the original face keeps displayed tapping the edition.
https://knowledge.autodesk.com/support/alias-products/getting-started/caas/CloudHelp/cloudhelp/2018/...
1 REPLY 1
fprico
in reply to: fprico
also the curbature comb is not displayed also it creates a crease where the vertices are
