Fusion Support
Edges or faces might be crossing
1 REPLY 1
agon1
116 Views, 1 Reply
Currently designing the Al Janoub stadium but cant figure out a way to fix the edges or faces that might be crossing. After making the shape i decided to weld all of the points in the end to create a pointy shape at the end of the geometry. Are there better ways to approach the modelling of this form?
I attached my file and a screenshot of the problem.
1 REPLY 1
glenn-chun
in reply to: agon1
Using quads (See Case 3 below) is the best way to fix Error 2.
Glenn Chun
Sr. Principal Engineer
Technology Administrators
