Here's one I have not seen before. Open the attached file and see if you can add an 0.5mm chamfer to the top or bottom of the central puck. Both edges seem to highlight correctly as one continuous circular path, even with Tangent chain turned off:
But when the Chamfer is executed, it stops at some random location, not even at the midline:
Close up:
Chamfering is possible up until the point at which the central puck is Combined with the Neonatal Barb body (where I've left the timeline marker). Even though the top and bottom of the puck were used to split away unwanted parts of the barb base, there still seems to be something unhappy about the resulting combined surfaces.
The attached file is relatively simple and all the bodies were created within this same Fusion 360 document.
Please note: This is not a question about how to get these edges to chamfer. I can work around the issue just fine. I'm documenting this in case the behavior seems to indicate something unexpected going on within Fusion 360.
