Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Drawing update error
1 REPLY 1
tkeding
183 Views, 1 Reply
I am currently working on the drawing of an assembly made from several linked parts and finalize the drawing. Today, when I tried to get the latest changes of the model, this error ocurred:
When I opened the Assembly Design file, I got the message that some part links were removed (probably by someone else working on the model), but none of the parts that were used in the drawing.
So, updating of the drawing is not possible. Also, everytime I try to insert a part of the assembly in the drawing, the program only inserts the last part I inserted in the drawing, no matter what part I choose.
Would it help if I delete this file and let Fusion download it again?
Can you help me solve this issue?
Thanks & Greetings
Labels (2)
1 REPLY 1
tkeding
in reply to: tkeding
Ok, deleting the corrupt file helped... did not even need to close the program 🙂
