Fusion Support
Drawing inaccessible - New Features
12 REPLIES 12
Message 1 of 13
jpgX6TC9
532 Views, 12 Replies
Hello
Two points :
1 - I can not access a drawing anymore. A blue wheel turns on the sticker. The right click is inoperative.
What to do ?
2 - The new features do not appear. I am in the last version.
I took as an example the quotation of the diameters.
Attached are two screenshots.
Thank you
Best regards
12 REPLIES 12
Message 2 of 13
karina.harper
in reply to: jpgX6TC9
Hi @jpgX6TC9
Can you:
share the files you are having issues with?
post your log files as a .zip?
When did this happen?
Karina Harper
Software QA Engineer, Fusion 360
Fusion 360 Webinars | Contact Support | EDU Support | Support Board Best Practices
Message 3 of 13
jpgX6TC9
in reply to: karina.harper
Hello Karina
Here are the log files.
I work on two computers.
On both computers, I do not have the new features and the software has become quite unstable.
For the file that is inaccessible, I can not send it to you because I can not download it …
There was no special action on my work.
Cordially
iMac sous Mac Os High Sierra (2012)
Macbook Pro with Mojave
> Le 24 janv. 2019 à 23:51, Autodesk Community > a écrit :
> Hi jpgX6TC9,
> karina.harper (Autodesk Support) mentioned you in a post. Join the conversation below:
> Re: Drawing inaccessible - New Features <>
> Hi @jpgX6TC9 <>
> Can you:
> share the files <> you are having issues with?
> post your log files <> as a .zip?
> Reply | Accept as solution <> | Give Likes <>
> Note: When you reply by email, your signature file if you set one up in your email client is displayed in the thread. If you don't want your signature file to appear in the thread, please remove it before replying.
> Manage your notification settings <> or unsubscribe. <>
> Go to site preferences <> to receive email notifications in another language.
> Privacy <> | Legal Notices & Trademarks <> | © Copyright 2018 Autodesk, Inc. All rights reserved.
Message 4 of 13
karina.harper
Hi @jpgX6TC9
Thanks for the reply. I don't see the logs attached to your message - can you try again?
Also, can you try accessing the file in your hub and sharing it through there? There are instructions at the bottom of the page here.
Karina Harper
Message 5 of 13
jpgX6TC9
OK
I Mac (2012) with Mac Os High Sierra
Jean Philippe
Message 6 of 13
karina.harper
Hi @jpgX6TC9
I still don't see those log files - can you try again?
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/How...
Karina Harper
Message 7 of 13
jpgX6TC9
> Le 29 janv. 2019 à 17:34, Jean Philippe a écrit :
> I am sorry.
> I uncompressed the files.
> Celui de l’Imac 2012 (High Sierra)
> Celui du Macbook Pro (Mojave)
Message 8 of 13
karina.harper
Salut @jpgX6TC9
S'il vous plait attacher le dossier ici - je ne vois rien dans votre poste.
Il faut utiliser le bouton ci-dessous:
((Please attach the folder here - I don't see anything in your post.
You'll need to use the button below:))
Karina Harper
Message 9 of 13
jpgX6TC9
Curious
See below
Here is a download link with 2 files : https://we.tl/t-qzpGJTbRCH <>
JPG
> Début du message réexpédié :
> De: Autodesk Community
> Objet: Reply by email can not be posted
> Date: 29 janvier 2019 à 18:59:20 UTC+1
> À: jpg@paragliding.tech
> Message posting failed due to one of the following reasons:
> 1. Your email contains locale which is not supported by community.
> 2. Parsing of the reply content failed.
> 3. Your reply failed to post. Review your email and confirm that you removed all email headers (from, to, subject) from your reply.
> To control which emails we send you, manage your subscription & notification settings <> or unsubscribe <>.
Message 10 of 13
karina.harper
Thanks for posting those - that worked. It looks like you are on version 2.0.5338 - we released an update that might fix your issue. Try updating and see if that resolves it.
Merci de les avoir posté, ca marche. Je vois que vous êtes à la version 2.0.5338 - nous avons publié une version nouvelle qui pourrait résoudre votre problème. Essayez la mise à jour et voyez si cela résout le problème.
Karina Harper
Message 11 of 13
jpgX6TC9
OK.
Merci
Good evening to you
Message 12 of 13
karina.harper
@jpgX6TC9
Did updating resolve the issue?
La mise à jour vous a-t-elle permis de résoudre le problème?
Karina Harper
Message 13 of 13
jpgX6TC9
Hello
I installed version 2.0.5350 after uninstalling everything.
I have access now to the drawing. Thank you.
However, the new features have not implemented as shown by the two screenshots.
E.g. : Better contextual tab highlighting in UI Preview or Diameter detection on side view for circular geometry.
It is not serious. But to see.
Have a good day
Jean Philippe
Technology Administrators
