I'm going through the training videos Fusion 360 Adoption.
Lesson 3 : Open/Close/Save
I can open the file like it says but when I'm told to upload and navigate to the file location I can't find the path to the files.
Do I need to download something else?
Robert
Solved by jhackney1972. Go to Solution.
I did a screencast to show you how to create a folder in your data folder and how to upload the data file to it. I also showed you how to move between folders in your project.
John Hackney, Retired
In lesson 3 open/close/save I can navigate to the file through workshop & events/fusion master. it then tells me to go to my master file and upload hit select and navigate to the open/close/save file.
The path is not on my computer. I assume it is supposed to be there because the tutorials are asking me to do this.
The folder you choose to download the practice files is up to you. The guy in the lesson just select one he created. In my screencast, I download the practice files to my folder C:\Publish and then expanded the zip file to reveal the file. By the way the file is not exactly named Open/Close/Save and you can see from my screen capture below.
The question he is trying to ask, and so am I......
Where can we download the mastery lesson files? The link you show in your screen cast is not on the web site where I am viewing the tutorials.
https://academy.autodesk.com/software/fusion-360
Thanks...
in this screen are all the videos when each is selected you can right click on the video and select download as. it worked for me.
