Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Downgrade from startup license to personal license?
I think I have to downgrade from startup license to the personal license.
What do I have to do, to get this done?
I have already some f360 - projects. Are they kept, if I downgrade the license?
Thanks in advance and stay healthy
gmelantoni
The data that you own under the account always stays there, regardless of the user license you have (trial, personal, commercial, startup).
What might change if you move into Personal is that there is some functionality you won't have access to. Check https://www.autodesk.com/products/fusion-360/personal to understand what's available on Fusion for Personal use.
Guillermo Melantoni
Senior Product Line Manager
“https://damassets.autodesk.net/content/dam/autodesk/logos/autodesk-logo-primary-rgb-black-small_forum.png”
ok, thank you for your answer.
So if I understand you right, all my projects will be available after downgrading, but there might be some functionality, that I loose?
At the moment, I think I can live with this.
Do I have to install a new client on my Mac, or can I just switch the license somehow?
Stay healthy
gmelantoni
No need to reinstall Fusion 360. When you log into Fusion 360, we take a look at your license and that defines what you see in the product. Your data is not impacted.
Guillermo Melantoni
Anyone planning to answer the actual question?
gmelantoni
Once your current Startup contract expires, you can then get a Personal license here: https://www.autodesk.com/products/fusion-360/personal
Once you do this, log out of Fusion and log back in, and you will see your new status.
Guillermo Melantoni
