Fusion Support
Document stuck uploading
27 REPLIES 27
Message 1 of 28
adamsa
1138 Views, 27 Replies
I have a document that is "still uploading" per the screenshot below. When I check the queue and look online, I don't see the document anywhere. I have also check on other computers and shows the same thing from within the app.
Issue is that it's counting against my editable documents? Any idea how to clear this?
27 REPLIES 27
Message 2 of 28
@adamsa I am checking with our engineering team on how to dismiss this download. By any change do you work on multiple machines or is this is a lab machine where multiple accounts log in on the same machine at different times?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 3 of 28
I work on multiple machines. I believe the issue stemmed from my desktop falling asleep (i failed to close fusion). Then picking up the work on my laptop. I got the notice of fusion running on my desktop and I suspended the session. but seems to have gotten stuck somehow.
Message 4 of 28
@adamsa Can you also please provide log files?
1. Go into Fusion - help - Support and disgnostics
2. Service utility
3. Run the gather system info
This will generate two zip files
4. We will need the Fusiondiagnosticslogs.zip file
Autodesk Fusion
Join Fusion Insider
Message 5 of 28
Does it matter which computer I do this from?
Message 6 of 28
@adamsa From both would be very helpful. Since we do not know which machine triggered this problem.
Autodesk Fusion
Join Fusion Insider
Message 7 of 28
Here you go. This is from my desktop where I believe the issue started from.
Message 8 of 28
@adamsa The log files unfortunately did not give us enough information. Here is a way to reset the editable documents in your queue. The below steps will remove all the editable documents and you will have to start marking things editable but this will remove the stalled ones.
  • Launch Fusion
  • Go Offline (manual switch)
  • Close Fusion
  • Rename the %APPDATA%\Autodesk\Neutron Platform\Options\<User ID>\login__ActiveDocuments file
  • Launch Fusion
  • Editable Document list should be empty
  • Mark a single document editable
  • Go Online
    Please let us know if this worked for you.
Autodesk Fusion
Join Fusion Insider
Message 9 of 28
i followed the steps up to here:
-Launch Fusion
-Go Offline (manual switch)
-Close Fusion
-Rename the %APPDATA%\Autodesk\Neutron Platform\Options\<User ID>\login__ActiveDocuments file
-Launch Fusion
-Editable Document list should be empty
Now my entire project shows no documents.
Message 10 of 28
@adamsa That is likely that nothing else was cached locally. Now if you go online in Fusion you should see all your documents and make each one editable.
Autodesk Fusion
Join Fusion Insider
Message 11 of 28
that looks to have worked. everything seems normal again and no hung up documents.
Message 12 of 28
@adamsa Thank you for confirming that this is working.
Autodesk Fusion
Join Fusion Insider
Message 13 of 28
can you give the steps to do this on a Mac?
Message 14 of 28
@diablozoe The Mac equivalent would be in
/Users/Mac USER ID/Library/Application Support/Autodesk/Neutron Platform/\Options\<User ID>\login__ActiveDocuments file
Autodesk Fusion
Join Fusion Insider
Message 15 of 28
Thanks, I had the same problem and your solution worked.
Message 16 of 28
Thanks. I have fixed the issue. Thanks to this post.
Message 17 of 28
Bonjour @adamsa
Je me suis inspiré de votre méthode pour supprimer les documents éditables.
J'ai bien lancé Fusion et activé le mode hors ligne avant de refermer Fusion
Etant sous Windows 11 je n'ai pas trouvé la variable suivante : %APPDATA%\Autodesk\Neutron Platform\Options\<User ID>\login__ActiveDocuments
Je l'ai donc recherché sur le disque système et je l'ai trouvé à cette adresse : "C:\Users\<User ID>\AppData\Roaming\Autodesk\Neutron Platform\Options\VL6DM49L2SV9\login__ActiveDocuments"
Je l'ai renommé en ajoutant une lettre : "login__ActiveDocuments" est devenu "login__ActiveDocumentss"
J'ai relancé fusion la liste des projets n'était pas vide mais tous les documents étaient en lecture seule.
J'ai donc supprimé les documents à l'exception de l'un d'entre eux.
J'ai rendu ce dernier éditable et je l'ai rendu éditable.
J'ai fermé Fusion et je l'ai relancé : il était comme neuf !
Merci beaucoup vos informations précieuses.
J'espère que cela aidera d'autres personnes et qu'elles n'auront plus de soucis avec un chargement bloqué.
Message 18 of 28
@christian_collins Glad the solution worked for you.
Autodesk Fusion
Join Fusion Insider
Message 19 of 28
Grx3D
in reply to: christian_collins
Merci !
Problème résolu merci a toi 🙂
Perso j'ai mis en Read only tout mes projet avant de faire la manip.
Le projet que j'avais supprimé est revenu dans ma liste, j'ai pu le supprimer définitivement 🙂
Message 20 of 28
it works!
