Fusion Support
Document is still uploading...
15 REPLIES 15
Message 1 of 16
Unbekannt353
2246 Views, 15 Replies
Hello, i am having similar issues to other members in here, however have not been able to fix it.
I am using fusions personal edition and am thus limited to 10 editable files. This wouldnt be a big issue if i had more than that, but while trying and failing to save my document yesterday night, i am today left with 8 files which are saying that they are still uploading. (unable to open or click)
files were created when trying to save a document which kept erroring due to locally linked files (which werent local? and have not presented issues in the 75 revisions before this..)
I have thus far tried the following without success:
Job Status
tried clearing the job status, job status list is empty
Updating Fusion
ive updated fusion to the latest version
Offline Mode
entering offline mode and or restarting did not solve the issue
Clear Cache Data
tried clearing the cache data both online and offline
Checking for the files online in web
tried checking to see if the files are present online (and maybe deleting them there)
files arent anywhere but on my local machine.
following: https://help.autodesk.com/view/fusion360/ENU/?caas=caas/sfdcarticles/sfdcarticles/File-stuck-in-uplo...
  • Text Command to remove the upload que
command ran successfully removing 0 from the que.
  • Manually clearing the upload que
following the guide deleting/moving files still left with the same que.
I have also tried this without success
-Launch Fusion
-Go Offline (manual switch)
-Close Fusion
-Rename the %APPDATA%\Autodesk\Neutron Platform\Options\<User ID>\login__ActiveDocuments file
For me there is no "Options" folder
-Launch Fusion
-Editable Document list should be empty
EDIT (it was in appdata not local, i found it):
renamed to _backup092024 for now, opening fusion 0/10 editable documents, documents are gone.
entering online mode again, they returned.
theres probably more that i tried however i may have forgotten by now.
attatched are the logs.
15 REPLIES 15
Message 2 of 16
@Unbekannt353 Can you please try the below?
  • Launch Fusion
  • Go Offline (manual switch)
  • Close Fusion
  • Rename the %APPDATA%\Autodesk\Neutron Platform\Options\<User ID>\login__ActiveDocuments file (OR) \AppData\Roaming\Autodesk\Neutron Platform\Options\<user ID> login__ActiveDocuments file
  • Launch Fusion
  • Editable Document list should be empty
  • Mark a single document editable
  • Go Online
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 3 of 16
that worked, thank you so much for the quick reply!
Message 4 of 16
I had the same problem this morning and this resolved my issue also. I just added "_OLD" to the end of the active documents file mentioned above and program generated a new "login_ActiveDocuments" file to replace it when I booted it up.
Thanks.
Message 5 of 16
This worked for me too, after I had tried everything that was listed above and finally this worked. Thanks so much!
Message 6 of 16
This didn´t work for me. I performed all the steps. But Fusion won´t launch without connection. So I need to reconnect to launch Fusion. Now I have 3 instead of 2 documents uploading. One with name, two without.
Message 7 of 16
Edit: was wrong understanding of "manual switch"
Now my list is empty!
Worked for me!
Message 8 of 16
THANK YOU! THANK YOU! Solved my issue when nothing else would. You Rock!
Message 9 of 16
It worked! (Must click View/Hidden items in file explorer first. login__ActiveDocuments is hidden) Thanks!
Message 10 of 16
Hello, I have followed this but then get stuck as there is no options folder after the neutron folder but then the options folder is not there .......
Message 11 of 16
@mojothesandman Can you please confirm if you looked for it in both locations? Also do you have the personal entitlement?
Autodesk Fusion
Join Fusion Insider
Message 12 of 16
OMG THANKS! I was stuck with 3 editable documents. Didn't get anywhere with my support case, tried ALL the steps. This is the only thing that worked.
FYI in case anyone is using a Mac and looking for the AppData folder:
  1. Open Finder from the Dock
  2. Click Go in the menu bar
  3. Select Go to Folder
  4. Type ~/Library/Application Support and press Return
Message 13 of 16
I will buy you, Sir, a beer, coffee or Tea if we ever meet. Thanks!
Message 14 of 16
how do i do this on mac?
Message 15 of 16
@whyismydogfat Please update to the latest Fusion 2.0.20508 and then follow this document - https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Files-stuck-in-Edi...
Autodesk Fusion
Join Fusion Insider
Message 16 of 16
This worked for me. 5 out of my 10 allowed documents were in this state. For those who may not know the appdata folder is hidden by default and must be unhidden. Big thanks from the Big Island of Hawaii, and I want to express my gratitude to Autodesk for making Fusion available at no cost to those of us who could never afford or justify a commercial license.
