Hello, i am having similar issues to other members in here, however have not been able to fix it.
I am using fusions personal edition and am thus limited to 10 editable files. This wouldnt be a big issue if i had more than that, but while trying and failing to save my document yesterday night, i am today left with 8 files which are saying that they are still uploading. (unable to open or click)
files were created when trying to save a document which kept erroring due to locally linked files (which werent local? and have not presented issues in the 75 revisions before this..)
I have thus far tried the following without success:
Job Status
tried clearing the job status, job status list is empty
Updating Fusion
ive updated fusion to the latest version
Offline Mode
entering offline mode and or restarting did not solve the issue
Clear Cache Data
tried clearing the cache data both online and offline
Checking for the files online in web
tried checking to see if the files are present online (and maybe deleting them there)
files arent anywhere but on my local machine.
command ran successfully removing 0 from the que.
following the guide deleting/moving files still left with the same que.
I have also tried this without success
-Launch Fusion
-Go Offline (manual switch)
-Close Fusion
-Rename the %APPDATA%\Autodesk\Neutron Platform\Options\<User ID>\login__ActiveDocuments file
For me there is no "Options" folder-Launch Fusion-Editable Document list should be empty
EDIT (it was in appdata not local, i found it):
renamed to _backup092024 for now, opening fusion 0/10 editable documents, documents are gone.
entering online mode again, they returned.
theres probably more that i tried however i may have forgotten by now.
attatched are the logs.
Solved by RajkumarIlanchelian. Go to Solution.
@Unbekannt353 Can you please try the below?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
I had the same problem this morning and this resolved my issue also. I just added "_OLD" to the end of the active documents file mentioned above and program generated a new "login_ActiveDocuments" file to replace it when I booted it up.
Thanks.
This worked for me too, after I had tried everything that was listed above and finally this worked. Thanks so much!
This didn´t work for me. I performed all the steps. But Fusion won´t launch without connection. So I need to reconnect to launch Fusion. Now I have 3 instead of 2 documents uploading. One with name, two without.
Hello, I have followed this but then get stuck as there is no options folder after the neutron folder but then the options folder is not there .......
\Options\<user ID> login__ActiveDocuments file
@mojothesandman Can you please confirm if you looked for it in both locations? Also do you have the personal entitlement?
%APPDATA%\Autodesk\Neutron Platform\Options\<User ID>\login__ActiveDocuments file (OR) \AppData\Roaming\Autodesk\Neutron Platform\Options\<user ID> login__ActiveDocuments file
Autodesk Fusion
Join Fusion Insider
OMG THANKS! I was stuck with 3 editable documents. Didn't get anywhere with my support case, tried ALL the steps. This is the only thing that worked.
FYI in case anyone is using a Mac and looking for the AppData folder:
@whyismydogfat Please update to the latest Fusion 2.0.20508 and then follow this document - https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Files-stuck-in-Edi...
Autodesk Fusion
Join Fusion Insider
This worked for me. 5 out of my 10 allowed documents were in this state. For those who may not know the appdata folder is hidden by default and must be unhidden. Big thanks from the Big Island of Hawaii, and I want to express my gratitude to Autodesk for making Fusion available at no cost to those of us who could never afford or justify a commercial license.
