Fusion 360 is crush every time when you open Display Detail Control with empty selection or multiple selection) .
All works properly only when you use it in default scenario: Select single Body → go to Explorer → Click on Body and open contextual menu → select Display Detail Control.
But if you have assigned hotkey for Display Detail Control and use it without selected entire body (empty selection or multiple body selected) Fusion will crush every time.
Hi @ponomarevcs
Could you please show me how you assigned hotkey for Display Detail Control?
I was not able to find a way to assign hotkey.
If you find my answer solved your question, please click the "Accept Solution" button
Sujay D'souzaCan't find what you're looking for? Ask the community or share your knowledge.
