Announcements
Fusion 360 Crashes when creating Drawing-->Reinstall
barney15e
Message 1 of 11
barney15e
After update to 2.0.14567,
When trying to create a Drawing from a Design, Fusion 360 would crash. I tried various ways to create a drawing and it would always crash.  It also crashed when trying to open a Drawing.
I used Remove Autodesk Fusion and then re-installed Fusion 360. That fixed the problem.
It may have just been something corrupt on my system as I don't see any recent posts about this problem.
M1 Mac Mini.
Replies (10)
Message 2 of 11
dsouzasujay
Hi @barney15e
Sorry to see that you're facing this problem. Is the crash is reproducible for all the designs when you create a drawing?
Do you receive any crash error reports that then generates a crash report ID? If so can you pass on one of the IDs?
If you find my answer solved your question, please click the "Accept Solution" button
Sujay D'souza
SQA Manager
Quality Assurance
Autodesk, Inc.
Message 3 of 11
barney15e
I did submit quite a few reports, but didn't note the ID.
It crashed when opening other drawings that were made prior to when the problem started.
I couldn't make a Drawing of any design I tried.
Message 4 of 11
dsouzasujay
Hi @barney15e
Could you please share the email id?
Sujay D'souza
SQA Manager
Quality Assurance
Autodesk, Inc.
Message 5 of 11
barney15e
I didn’t write any down. If you know how I can find it after the fact, I can submit them.
Message 6 of 11
lance.swan
I have a similar issue and a reinstall did not solve the problem.
Report ID 333197790 refers as an example.
Message 7 of 11
dsouzasujay
Hi @lance.swan ,
Thank you for sharing the report, I would like to know on which mac OS version you are working.
@barney15e , As i mentioned earlier, Email ID works if you have not noted the crash Report id.
Sujay D'souza
SQA Manager
Quality Assurance
Autodesk, Inc.
Message 8 of 11
lance.swan
I’m using macOS Ventura.
Message 9 of 11
lance.swan
This post refers in the Support Forums: https://forums.autodesk.com/t5/fusion-360-support/fusion-360-crashes-when-creating-or-updating-drawi...
It appears to be a macOS Ventura issue.
Message 10 of 11
dsouzasujay
Hi @lance.swan
Yes, looks like Ventura  specific issue.
Sujay D'souza
SQA Manager
Quality Assurance
Autodesk, Inc.
Message 11 of 11
dsouzasujay
Hi @barney15e,
Thank you for sharing the email address.
I see you are on mac OS 13 Ventura, More details on this Forum Thread
Sujay D'souza
SQA Manager
Quality Assurance
Autodesk, Inc.
