Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Dimension lines showing but no dimensions in Drawing Workspace
4 REPLIES 4
DrStu
250 Views, 4 Replies
DrStu
Observer
Observer
When I create a drawing from a design, the dimension tool will place dimension lines but no dimensions (see cup below). Previously, Fusion would automatically generate the dimensions of the object (see box lid below). Is there a checkbox or preference in the drawing mode that I am missing?
4 REPLIES 4
ClintBrown3D
in reply to: DrStu
ClintBrown3D
Hi @DrStu
Please share a link to the drawings, so that we can take a look.
Hi @DrStu
DrStu
in reply to: ClintBrown3D
DrStu
Observer
Observer
Here it is:
https://a360.co/3hlg8gR
Thank you
Here it is:
Thank you
ClintBrown3D
in reply to: DrStu
ClintBrown3D
Hi @DrStu
If you toggle the text height, it fixes the issue.
What I'd like to understand is if this is an issue on all new drawings, or just this one?
Hi @DrStu
DrStu
DrStu
Observer
Observer
Hi Clint,
Problem solved. Thank you so much. Yes, it happens on all drawings, so clearly there is no default height set. Text Height simply comes up as Text Height in the Document Settings. This is despite it being set in the Preferences (see below)!!! Weird.
Hi Clint,
