When I create a drawing from a design, the dimension tool will place dimension lines but no dimensions (see cup below). Previously, Fusion would automatically generate the dimensions of the object (see box lid below). Is there a checkbox or preference in the drawing mode that I am missing?
Solved by ClintBrown3D. Go to Solution.
Hi @DrStu
Please share a link to the drawings, so that we can take a look.
Hi @DrStu
If you toggle the text height, it fixes the issue.
What I'd like to understand is if this is an issue on all new drawings, or just this one?
Hi Clint,
Problem solved. Thank you so much. Yes, it happens on all drawings, so clearly there is no default height set. Text Height simply comes up as Text Height in the Document Settings. This is despite it being set in the Preferences (see below)!!! Weird.
