Message 1 of 9
I am working with a multi-part .step from a vendor and the cover of the enclosure has some weird zero-thickness triangles popping out if it. I can select them, but not manipulate them, and trying to delete them causes Fusion to crash hard. When viewed in Autodesk's online viewer they are not present. The file is a "clean" download from the vendor site.
(Note that the cover is Body3, while Body1 and Body2 are some features that are somehow separated from the main body. This appears to be a separated but unrelated issue with the vendor's CAD.)
Might someone have any ideas as to the cause? A temporary fix to just hide them would be appreciated too, since I have to make some renderings today.
