Im trying to align some pipe bodies to different angled lines, to build a geodome. So when I make a circular pattern and mirror, it will all align. I tried many things but nothing works, anyone has an idea of how to do it? Im putting some prints do exemplify
Solved by jhackney1972. Go to Solution.
If you truly want to use Bodies, then the Align command will do the trick.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
Did my post answer your question? If so, please select the "Accept Solution" icon to do three things. First it allows others to find a solution to a similar question, two, it closes the Forum post and last, it acknowledges that you accept the solution given. If you need further help, please ask. If you like to read why "Accept Solutions are important, take a look at this webpage.
John Hackney
Retired
