The create drawing dialog does not respond to mouse clicks, neither 'Don't show me this again nor the OK button.
The only thing that removes the dialog is the Enter key.
Fusion 2.0.13881
Active Plan: Fusion 360, Subscription
macOS 12.3.1 x86_64 (21E258) on MacBookPro15,1
Solved by pmbouvier. Go to Solution.
Solved by ClintBrown3D. Go to Solution.
Hi @pmbouvier
I'm sorry to hear that you are having trouble.
Is this behaviour specific to a certain dataset? Or do you see this every time you create a drawing?
Please share a link to your model, so that I can ask the team to investigate this, or if it is sensitive, feel free to send it directly to me Clint. Brown {a} Autodesk.com
cc: @nemadec
Hi @pmbouvier
That dialogue will only appear when there are T-spline bodies, meshes or Surface bodies in the model.
If you remember which model caused the problem initially, please send it on to me, and I'll ask the team to investigate.
Hi @pmbouvier
This works flawlessly on my mac mini. I wonder if your system just needed a reboot?
It works for me too now, Clint; I can't get the dialog box to come up anymore. If it happens again I will re-open this thread. Thank you.
