Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Create drawing dialog non responsive
8 REPLIES 8
Message 1 of 9
pmbouvier
269 Views, 8 Replies
The create drawing dialog does not respond to mouse clicks, neither 'Don't show me this again nor the OK button.
The only thing that removes the dialog is the Enter key.
Fusion 2.0.13881
Active Plan: Fusion 360, Subscription
macOS 12.3.1 x86_64 (21E258) on MacBookPro15,1
8 REPLIES 8
Message 2 of 9
pmbouvier
in reply to: pmbouvier
Forgot to mention.... the cursor turns into a watch icon when hovered over the dialog.
Message 3 of 9
ClintBrown3D
Hi @pmbouvier
I'm sorry to hear that you are having trouble.
Is this behaviour specific to a certain dataset? Or do you see this every time you create a drawing?
Please share a link to your model, so that I can ask the team to investigate this, or if it is sensitive, feel free to send it directly to me Clint. Brown {a} Autodesk.com
cc: @nemadec
Message 4 of 9
pmbouvier
in reply to: ClintBrown3D
Hi Clint,
It happens no matter what I try to draw, it seems.
I just opened another (different) project and it did the same thing.
So I wanted to do a screen capture instead of a screen grab so you could
see the pointer as a watch.
However, I cannot duplicate the problem; the dialog box does not appear.
I closed and re-opened Fusion, opened the same project, selected
Drawing->From Design, and could not duplicate the problem because the
dialog box no longer appears.
I even rebooted the OS, opened Fusion, opened a project, and selected
drawing, and still, I could not duplicate the problem (that is, the dialog
does not appear). I tried this on three different projects (two of which
had previously exhibited the issue), but the dialog box does not appear.
Perhaps one of the previous cycles I had selected "do not show this message
again".
Is there a way I can make the dialog appear again?
If you like I can send you a link to a project that
Peter
Message 5 of 9
ClintBrown3D
Hi @pmbouvier
That dialogue will only appear when there are T-spline bodies, meshes or Surface bodies in the model.
If you remember which model caused the problem initially, please send it on to me, and I'll ask the team to investigate.
Message 6 of 9
pmbouvier
Hi Clint,
I can't re-create the issue even with the project that had the original
problem, which does have T-splines in it.
I've attached a link to the project file that caused the original issue; I
was trying to create a drawing of Bezel and PR mount->stuffing, which had
originally caused the issue, let me know if you can't open it.
https://drive.google.com/file/d/1om3sUjJXLQfRPgsYiv411A6iwONLkdYm/view?usp=sharing
Peter
Message 7 of 9
ClintBrown3D
Hi @pmbouvier
This works flawlessly on my mac mini. I wonder if your system just needed a reboot?
Message 8 of 9
pmbouvier
It works for me too now, Clint; I can't get the dialog box to come up anymore.  If it happens again I will re-open this thread.  Thank you.
Message 9 of 9
pmbouvier
Adding these snapshots for completeness.Screen Shot 2022-08-23 at 4.38.57 PM.pngScreen Shot 2022-08-23 at 7.49.18 AM.png
