Today I cannot use Fusion360 because it crashes while editing any sketch, it doesn't matter if it's a new one or of I try to edit an old one, new file or old file.
Does any body has the same problem?
While it is loading at the beginning shows this error window:
Solved by Imprenta3D. Go to Solution.
Dear @Imprenta3D
Have you tried to reinstall Fusion 360?
No problem @Imprenta3D
Please click the Accept Solution if you feel that my response has answered your query.
Hello again.
I've tried to uninstall and reinstall Fusion 360, but now a new message appears and I cannot finish the instalation:
Attached goes the log file.
Any help is welcome.
After deleting the Autodesk folder, I could reinstall Fusion 360 and for the moment it seems that works again.
