Announcements
Sharing public link crashes fusion
CuttingEdgeManufacturing
I havent nailed it down yet, but seems everytime I click "share the latest version with anyone using this public link" toggle, it crashes on me. but when i restart f360 and try this, it will work.
only thing i think is consistent is that i have multiple files open the first time, and only 1 file open the second time.
hoping this can get resolved!
Replies (11)
karina.harper
Autodesk Support
Autodesk Support
Hi @CuttingEdgeManufacturing
I see you posted this in the Insider problem reports as well - is this happening in the Insider build that released today? What version of Fusion are you on?
On a quick test I couldn't reproduce, does it seem to be occurring with a particular file?
Cheers,
Karina
Karina Harper
Software QA Engineer, Fusion 360
Fusion 360 Webinars | Contact Support | EDU Support | Support Board Best Practices
yes i posted it on the insider forum as well. it is on the insider build. but it has been happening the last few days so its not inclusive only to todays insider release.
its not specific to a certain file. however it is for  larger assembly files.
karina.harper
Autodesk Support
Autodesk Support
Ok - yeah I see that in your crash reports.
Which hub are you using? Can you check this setting in your hub? I see an error in the logs indicating there may be a conflict.
Cheers,
Karina
Karina Harper
Im on a team for our company, "Cutting Edge Engineering"
here is screenshot of my settings you asked about.
karina.harper
Autodesk Support
Autodesk Support
Hm ok. Maybe I misinterpreted the error there, I'm thinking now it's just indicating that there is no public link and one needs to be created.
Here's the error:
20221012T115438 E  29632 Network failed request - response OK, bad contains error:
	"headers":	{
		"api-version":	"9.30.1.ba73d670c3",
		"csrf-cookie-name":	"a360_csrf_cookie",
		"request-id":	"ContentBrowser_a50dd9f7-d42c-4172-adf4-088fc170d6e9__GetPublicLinkStatus_ad98422b-0cce-45b3-b2e1-50e8b83c9c6e",
		"served-at":	"1665590077325",
		"served-by":	"https://www.autodesk.com/fusion-team",
		"time-taken":	"0"
	"error":	{
		"id":	"EXCEPTION_NO_ACTIVE_SHARE",
		"message":	"No active share found for this item",
		"messageKey":	"EXCEPTION_NO_ACTIVE_SHARE"
URI:https://cuttingedgemanuf.autodesk360.com/shares/api/shares?versionUrn=dXJuOmFkc2sud2lwcHJvZDpmcy5maWxlOnZmLnMwX1I4dDh6U0RtLXptbHFSLTV2Y0E_dmVyc2lvbj0zNQ
...X-Request-ID: ContentBrowser_a50dd9f7-d42c-4172-adf4-088fc170d6e9__GetPublicLinkStatus_ad98422b-0cce-45b3-b2e1-50e8b83c9c6e
...response: HTTP/1.1 200 OK
Access-Control-Expose-Headers: Timing-Diagnostics
Cache-Control: no-cache, no-transform, must-revalidate
Connection: keep-alive
Content-Length: 449
Content-Type: application/json;charset=UTF-8
Date: Wed, 12 Oct 2022 15:54:37 GMT
Expires: 0
P3P: CP="IDC DSP COR ADM DEVi TAIi PSA PSD IVAi IVDi CONi HIS OUR IND CNT"
Pragma: no-cache
Server: nginx
Set-Cookie: JSESSIONID=A9FA6C7D23104E5D55F71D27EEFD79B5; Path=/shares; Secure; HttpOnly
Timing-Diagnostics: STUB(92-159), CACHE(191-71), OTHER(1-33), DB_COUT(10-0), DB(11-13), DB_CIN(10-19), WIP(2-88), HTTP_TRANSPORT(1-42), TOTAL(318-243)
X-XSS-Protection: 0
		ThreadID: 29632, Function: Ns::Network::ReqUtils::logRequestError, Line: 322
Then gets caught in a loop with this over and over - presumably trying to create the public link for the first time:
20221012T115452 I   7392 PushNotification broadcasting 0122 a360prod%3Agroup%3A168783565 groupSubscription
   {"message":[{"message":{"eventType":"WipContentAvailable","wipVersionUrn":"urn:adsk.wipprod:fs.file:vf.s0_R8t8zSDm-zmlqR-5vcA?version=14","state":"CONTENT_AVAILABLE","projectDmid":"a360prod:group:168783565","branch":"master","branchUrn":"urn:adsk.wipprod:dm.branch:8R-L_YKeTZuLXtkQgw88AA","parentFolderUrn":"urn:adsk.wipprod:fs.folder:co.2wI0sBd4SqejfthBJjYJFQ","name":"1000-190-300","modifiedBy":"BLBXNGUJ5HS3","modifiedTime":"2022-08-17T15:40:00+0000","eventId":"c9074072-4c07-43e5-8547-885dff9862fe","sourceServiceTrackingId":"ContentBrowser_e62867ac-aa07-4355-a1e7-5551bc3d7e5f__CreatePublicLink_7e4cf640-37f8-4caa-b5bc-3f8c7e2ec568-Clone-0.WIP-02e8ea59-6afc-48fe-8dfa-7ab0e899e4d0"}}],"channelStatus":["available"]}
Your two crashes from today look pretty similar though they are in different buckets. The other most recent (10/3) looks a bit different.
Anyone else that is a part of your hub having this problem? I have a hunch that it is hub related, but I'll test on my PC as well.
Cheers,
Karina
Karina Harper
We luckily don't share links to much. sometimes we send them to customers, but lately we are using the 3d viewer in browser from those links to view the assemblies so we can put the parts together.
ill ask around if the other guys have the same issue.
I had another guy try it and it crashed for him as well.
i then tried right clicking the file in the explorer, and clicked share link so far that is working everytime. laggy but it works.
i then noticed one of the files i just shared a link with, using the file browser scenario, doesnt have a share link in the file drop down.
hope this info helps
karina.harper
Autodesk Support
Autodesk Support
When you say 'explorer', are you on Teams (the web view) or in the data panel (menu on the left in Fusion)?
Can you try toggling the file sharing switch off and back on for me?
Karina
Karina Harper
the data panel sorry.
i switched it off saved. then switched it back on and saved.
karina.harper
Autodesk Support
Autodesk Support
Ok - any improvement in behavior after toggling that off/on?
Karina
Karina Harper
So far so good. i tried doing a screen recording of the exact same workflow i had been using. all 3 times i tried it, it worked.
if i have the isssue again ill bring it back to here.
