Fusion Support
Configuration Parameters not saving
1 REPLY 1
Riley_Amara
124 Views, 1 Reply
I'm creating a configuration table with variations of a single design and I've started noticing that some of the parameters I adjust aren't saved when I save the file. I finished the project, closed it, then opened it again and several parameters were back to older versions. I tried activating each configuration before closing it, it seemed to have no impact.
This is how it started
Before EditBefore Edit
The corrected parameters
CorrectedCorrected
And this is what I saw after fixing it, activating every configuration, saving and closing the file, and then re-opening it.
After saving and reopening the file.After saving and reopening the file.
Thanks in advance for any help.
1 REPLY 1
karina.harper
in reply to: Riley_Amara
Hi @Riley_Amara
Would it be possible for you to share the design with me? Either here in the forum or you can DM me directly. That is strange behavior. 🤔
Cheers,
Karina
Karina Harper
Software QA Engineer, Fusion 360
Fusion 360 Webinars | Contact Support | EDU Support | Support Board Best Practices
