Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Configuration Parameters not saving
1 REPLY 1
Riley_Amara
73 Views, 1 Reply
I'm creating a configuration table with variations of a single design and I've started noticing that some of the parameters I adjust aren't saved when I save the file. I finished the project, closed it, then opened it again and several parameters were back to older versions. I tried activating each configuration before closing it, it seemed to have no impact.
This is how it started
Before EditBefore Edit
The corrected parameters
CorrectedCorrected
And this is what I saw after fixing it, activating every configuration, saving and closing the file, and then re-opening it.
After saving and reopening the file.After saving and reopening the file.
Thanks in advance for any help.
1 REPLY 1
karina.harper
in reply to: Riley_Amara
Hi @Riley_Amara
Would it be possible for you to share the design with me? Either here in the forum or you can DM me directly. That is strange behavior. 🤔
Cheers,
Karina
Karina Harper
Software QA Engineer, Fusion 360
Fusion 360 Webinars | Contact Support | EDU Support | Support Board Best Practices
Technology Administrators
