Fusion Support
Concrete hatch pattern
2 REPLIES 2
stollartist64
4473 Views, 2 Replies
Hi, I see several hatch patterns to pick from in the pull down (after dbl clicking hatch in drawing to change properties).  I need concrete hatch pattern. Is it available in fusion 360 or is there a download out there that will work. Thanks for any advice. I have a drawing due an need to show the concrete.
L
2 REPLIES 2
Hi @stollartist64 ,
I do not believe so. Based on the options for Hatch in Fusion - I only see ANSI 31 to ANSI 38. Based on the standard below, concrete is not apart of this.
James Youmatz
Product Insights Specialist for Fusion 360, Simulation, Generative Design
Thanks for the reply...So is there any way I can create, add or download a new hatch pattern?
@James.Youmatz wrote:
Hi @stollartist64 ,
Hi @stollartist64 ,
Technology Administrators
