Hi, I see several hatch patterns to pick from in the pull down (after dbl clicking hatch in drawing to change properties). I need concrete hatch pattern. Is it available in fusion 360 or is there a download out there that will work. Thanks for any advice. I have a drawing due an need to show the concrete.
L
Hi @stollartist64 ,
I do not believe so. Based on the options for Hatch in Fusion - I only see ANSI 31 to ANSI 38. Based on the standard below, concrete is not apart of this.
Thanks for the reply...So is there any way I can create, add or download a new hatch pattern?
@James.Youmatz wrote:
Hi @stollartist64 ,
Hi @stollartist64 ,
